AutoCAD® Drawing Databases (DWG / DXF)
AutoCAD® drawing databases in the .dwg and .dxf format can be converted to WinProp building databases. However, not all object categories available in AutoCAD®, are supported by the converter. The following list shows the AutoCAD® object categories supported by the converter module.
For the conversion of AutoCAD® databases to the WinProp format the following object categories are supported:
AutoCAD® Object Categories | Indoor Mode | Urban Mode | Overlay Mode |
Proxy Objects 2) | |||
2D Polyline | - | ||
2D Solid | |||
3D Box | - | - | - |
3D Face | - | ||
3D Mesh | - | - | - |
3D Polyline | |||
3D Solid | |||
3D Sphere | - | - | - |
3D Surface | - | - | - |
Arc | - | ||
Arc aligned text | - | - | - |
Circle | |||
Donut | - | - | - |
Ellipse | |||
Hatch | - | ||
Line | - | ||
MLine | - | - | - |
MText | - | - | - |
MInsertBlock | - | - | - |
PolyFaceMesh | - | ||
Polygone | |||
PolygonMesh | - | - | - |
Polyline | |||
Text | - | - |
Note:
- The AutoCAD® objects must have a closed form, to be converted to urban buildings.
- The current version supports polyline and polygon proxy objects.
- The AutoCAD® objects must have a height value assigned for a correct conversion.
