Create Drawbead
Create a drawbead from a bead line.
- On the ribbon, click the Die Design tab.
Click the Drawbead icon.
Select the Drawbead tool on the secondary ribbon.
Select the die.
If you created a matching die and would like the drawbead created on both dies, use box selection to select both dies.
- Select the bead line(s).
In the guide bar, select the bead shape.
- Rectangular
- Circular
In the guide bar, select the endbead shape.
- Tangent Endbead
- Elliptical Endbead
- Round Endbead
In the guide bar, select a trim option, and then right-click to confirm.
- Trim and Edge Fillet
- Trim and Face Fillet
- Optional: If you would like to adjust the fillet radius, click a fillet, and enter a Radius.
- Right-click to create the drawbead.
Edit the drawbead.
To Do this Add a bead profile While holding down Alt, click anywhere on the bead line. Create copies of a bead profile - In the guide bar, click Edit Drawbead.
- Select Copy Drawbead.
- Select a source bead profile.
- While holding down Alt, click anywhere on the bead line.
Change a bead profile Length or Radius - Click a handle, enter a Radius, then press Enter.
- Click a handle, enter a Length, then press Enter.
Edit a bead profile shape - Click a bead profile.
- In the guide bar, select Rectangular or Circular.
Edit an endbead angle Click the blue point on the end of the bead. - Click the white arrow, enter an Endbead Angle, then press Enter.
- Drag the white arrow.
Note: The endbead angle has minimum and maximum angles of 20 and 60 degrees.Copy the parameters from one bead profile to another - In the guide bar, select Pass Drawbead Parameters.
- While holding down Alt, select the target bead profiles.
- Right-click and select Update.
Clear the selection In the guide bar, click
. - Right-click and mouse through the check mark to exit, or double-right-click.
