Suppress or Unsuppress Entities
Suppress or unsuppress an entity using the context menu in the Model Browser.
Tip:
- You can remove an entity from the display and include it in calculations by hiding it in your model.
- To exclude an entity from analysis, select the entity and select the Ignore for Structural Analysis checkbox in the Property Editor.
Suppress
Suppress an entity using the context menu in the modeling window or in the Model Browser.
- Press F2 to open the Model Browser.
                Right-click the entity name, and then select Suppress on
                    the context menu.
                The suppressed entity is displayed in grayed-out, italicized text in the Model Browser and is removed from the modeling window.
Unsuppress
Unsuppress an entity using the context menu in the Model Browser.
                Right-click the grayed-out, italicized entity name, and then click
                        Unsuppress on the context menu.
 The entity is restored in the model.
