Basic Settings
To get started configure these basic settings.
  • Import: Define if you use material data from local or WEB.
  • Current Working Directory: Specify the path for material cards, sessions, and configuration files.
  • Material Data Directory: Specify the path for material data files (not saved in the working directory).
  • HyperWorks Solver Directory: Specify the HyperWorks installation location.
  • Add or Remove the strain-rate values for the modeler as required.
  • Specify the User Information Contact details base curve after multiple processing stages.
Figure 1. Basic Settings
Basic Settings
