Side Toolbar
Use the toolbar keys to save the session with configurations applied, reload, export curves, quit, and finish.
- You can save the workflow steps in a configuration file, and the loaded curves, fitting, and approximation in a session file.
- Use the forward arrow => key to save the configuration file and the back arrow <= key to read it in again.
- Click S to save the session and L to reload it.
- Click Q to quit the Modeler session and release the used licenses.
- Click X to finish the session.
- Click ? for help.
You can toggle the (x,y) button for export curves at different points
with right click and select:
- Create Eng. curves
- Create True curves
- Create True pl. curves
- Create Final curves
Figure 1. Toolbar Menu
