Import Data from AMDC
Import data files from Altair Material Data Center (AMDC) to AMM.
Specify the AMDC application URL in the Settings tab.
  1. Select AMDC in the Settings tab.
  2. Switch to Modeler tab and click Import.
  3. Click Sign in and login to AMDC using your Altair One log in credentials.
    Figure 1. Import Data from AMDC
  4. Select a required material.
    Use the left navigation pane to do a quick search or filter the required material.
  5. Click Material Modeler in the right pane.
    Figure 2. Select Material
  6. Select the required temperature for the material.
  7. Click Download to import the material data in AMM.
    Figure 3. Download Material in AMM
