Update Model to New Design Position
Condition
This alert appears when using the Update Model feature on the animation toolbar: Use this time or frame as the new design position?
Remedy
Do one of the following:
- Yes: Changes the model design position to the current frame, deletes the last motion analysis, and exits the Review Motion Results tool.
- No: Aborts the Update Model operation without making any changes.
Tip: If you have any parts configured off, keep in mind that
they will not be updated. If you configure them back on, any
dependent connections may be incompatible with the new design
position.
