An explicit is solved by calculating results in small time increments or time steps. The size of the time step depends
on many factors but is automatically calculated by Radioss.
The contact interface time step is calculated in two different ways. First, based on stiffness and second, based on
the velocity of the secondary nodes.
The time step of the initial model is output to the Starter output file. Whereas the time step of a running model
can be output to the animation files.
Composite materials consist of two or more materials combined each other. Most composites consist
of two materials, binder (matrix) and reinforcement. Reinforcements come in three forms, particulate,
discontinuous fiber, and continuous fiber.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of
OptiStruct and simultaneously using the Radioss solver for analysis.
The nodal time step control is activated for a simulation by using the option:
/DT/NODA/Keyword3/Iflag
With the time step of a node in the mesh defined as:(1)
Where,
Nodal mass
Equivalent nodal stiffness
Note: If the mass of a node increases or the stiffness decreases, then the time
step of the simulation increases.
By default, the nodal timestep is applied to the entire model. If
Iflag=1, an additional line with a group
node set ID is input after the scale factor and time step. This can be used to apply
the nodal time step control to a group of nodes /GRNOD that have
been defined in the Starter.
Note: No matter which Keyword3 option
is used, only one /DT/NODA/Keyword3/Iflag option can be used
at a time in an Engine file. If multiple ones are included, only the last one is
used.
/DT/NODA/CST
/DT/NODA/CST is by far the most popular option for maintaining or
increasing the time step in a simulation. Radioss will
automatically add mass to nodes to maintain the entered value. If needed, the mass
will be added at the beginning of the simulation to meet the entered value.
Advantages and
Disadvantages
Increase the nodal mass via /DT/NODA/CST
is the easiest way to increase the time step of a model or prevent a time step
from dropping below a certain value during the simulation. Good engineering
judgement must be used to determine how much mass is an acceptable amount to be
added to a model. Adding too much mass can affect the physics by increasing the
kinetic energy of a drop or impact simulation. This is because the object being
simulated weighs more than the real part. Increased mass can also change the
high frequency behavior of a model which can be very important in very high
speed impacts such as ballistics, or explosions.
In general, it is
recommended to keep the amount of mass added to less than 5%. However, larger
mass increases may be acceptable in some types of simulation. For example, in
quasi-static simulations the velocities are usually small, so adding mass does
not greatly increase the kinetic energy. For those reasons, it is recommended to
check the mass increase in the model by running a simulation without or with
reduced mass scaling and comparing the results. If added mass results in added
kinetic energy, the energy error calculated by Radioss will be positive.
Choose a Time Step for Mass
Scaling
To determine how much mass will be added to a model, Radioss calculates a target time step for different
amounts of percent mass increase. The target time step is calculated for percent
mass increases from 0.5% to 10% for time step scale factors
() of 0.9 and 0.67. This information is printed in a
table and a graph in the Starter output file.
Note: This estimation is valid at
first cycle only. The added mass can increase during the run because of
element deformation or contacts which means the added mass can become higher
than the value expected from the Starter estimation.
The target time step and scale factor can then used in
/DT/NODA/CST.
Check for Mass Increase
The total
mass increase is listed in the Engine output file in the last column titled,
MAS.ERR. Using the animation output option
/ANIM/NODA/DMASS or /H3D/NODA/DMASS,
the relative mass increase per node can be visualized in a post-processor as a
contour plot. Both the total mass error and nodal mass error represent the
change in mass divided by the original mass at the beginning of the
simulation.(2)
With,
Where,
Initial mass at the beginning of the simulation for each Engine
file
Current mass
Note: The initial mass is reset at the beginning of every Engine file
simulation and the total mass increase should be added from all the Engine
output files.
The global time history mass and energy curves
can be plotted to understand how the increased mass effects the simulation.
Note: That part mass output using /TH/PART does not
include the mass added, due to mass scaling.
/DT/NODA/SET
Reduces the equivalent nodal stiffness () to maintain the entered
value. This reduction in stiffness also changes the physics of a simulation and
is typically only used when modeling fluids.
/DT/NODA/STOP
Stops the simulation when the simulation’s time step drops below the entered
value. Many times, a reduction in time step is caused by a model's instability,
so stopping the simulation can be useful to diagnose the issue.
