Contact Interface Time Step Control
The contact interface time step can be controlled using the Engine options:
  • /DT/INTER/Keyword3/Iflag
  • Δ T sca Δ T min
For all the Keyword3 options, the action taken will occur when Δ T min ≥ Δ T s c a * Δ t int e r f a c e MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WGubWaaSbaaSqaaiGac2gacaGGPbGaaiOBaaqabaGccqGHLjYScqqH uoarcaWGubWaaSbaaSqaaiaadohacaWGJbGaamyyaaqabaGccaGGQa GaeuiLdqKaamiDamaaBaaaleaaciGGPbGaaiOBaiaacshacaWGLbGa amOCaiaadAgacaWGHbGaam4yaiaadwgaaeqaaaaa@4E3C@ where, Δ t i n t e r f a c e = min ( Δ t i n t e r   n o d a l , Δ t k i n ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WG0bWaaSbaaSqaaiaadMgacaWGUbGaamiDaiaadwgacaWGYbGaamOz aiaadggacaWGJbGaamyzaaqabaGccqGH9aqpciGGTbGaaiyAaiaac6 gacaGGOaGaeuiLdqKaamiDamaaBaaaleaacaWGPbGaamOBaiaadsha caWGLbGaamOCaiaabccacaWGUbGaam4BaiaadsgacaWGHbGaamiBaa qabaGccaGGSaGaeuiLdqKaamiDamaaBaaaleaacaWGRbGaamyAaiaa d6gaaeqaaOGaaiykaaaa@5932@ is the minimum of contact stiffness time step and the kinetic time step as defined in Contact Interface Time Step. If Iflag=1, then a second line with additional input is entered for /DT/INTER/AMS.
Note: This control is only used with contact interfaces with nonlinear stiffness, TYPE7, TYPE10, TYPE11, TYPE19, and TYPE21.
/DT/INTER/CST
Automatically increases the mass of nodes involved in contact to maintain the entered value. Normally this option is not useful since contact secondary nodes with low time steps typically have high penetration into the contact gap and when mass is added their kinetic energy increases which causes increased penetration and thus model instability. The amount of added mass should be monitored during and checked after the simulation in the same manner as /DT/NODA/CST.
/DT/INTER/DEL
Removes nodes involved in a contact interface that are causing the time step of the simulation to drop below Δ T min . This option can be very useful to maintain a specified time step, but if the number of removed nodes is too large, then the contact will not be correct, and the results may not be accurate.
/DT/INTER/STOP
Stops the simulation when the contact interface time step drops below the entered Δ T min value. Many times, a reduction in time step is caused by a model's instability, so stopping the simulation can be useful to diagnose the issue.
/DT/INTER/AMS
Applies Advanced Mass Scaling to interface secondary nodes to maintain the constant time step, Δ T min . Refer to Advanced Mass Scaling (AMS) for more information.
