/PROP/TYPE34 (SPH)
Block Format Keyword Describes SPH property set.
| /PROP/TYPE34/prop_ID or /PROP/SPH/prop_ID | |||||||||
| prop_title | |||||||||
| mp | skew_ID | h_1D | |||||||
| order | h | hmin | hmax | ||||||
| hcst | |||||||||
Definition
| prop_ID | Property
identifier. (Integer, maximum 10 digits) |
| prop_title | Property
title. (Character, maximum 100 characters) |
| mp | Mass of the
particles. (Real) |
| Quadratic bulk
viscosity. Default = 2.0 (Real) |
| Linear bulk
viscosity. Default = 1.0 (Real) |
| Conservative smoothing
coefficient. (Real) |
| skew_ID | Skew identifier to define
the initial orthotropic directions in the case of
skew_ID ≠ 0 (means property is
orthotropic). (Integer) |
| h_1D | Smoothing length change
based on volume. 5
(Integer) |
| order | SPH correction order.
(Integer) |
| h | Smoothing length (not
considered if h_opt =
3). Default: see 1 (Real) |
| Coefficient for solving
tensile instability. Default = 0.0 (Real) |
| hmin | Scale factor for the minimum initial smoothing length
h for h_1D =
3. Default = 0.2 (Real) |
| hmax | Scale factor for the maximum initial smoothing length
h for h_1D =
3. Default = 2.0 (Real) |
| hcst | Constant used to compute initial smoothing length
h for h_1D =
3. Default = 1.2 (Real) |
Example (Bird Strike)
#RADIOSS STARTER
/PROP/TYPE34/3000001
BIRD_sphv1 (unit kg_mm_ms) data from Example 49 - Bird Strike on Windshield
# mp beta alpha alpha_cs skew_ID h_1D
1.725149E-4 2E-30 1E-30 0 0 0
# order h xi_stab hmin hmax
0 6.286 0 0 0
# hcst
0
#ENDDATA
- Default value for smoothing
length if h_1D < 3 is set
as:
which corresponds to the inter-particles distance when the particles distribution is hexagonal compact.
For face centered cubic and hexagonal compact net distribution, the recommended smoothing length is the pitch entered when generating the SPH particles.
If h_1D = 3, the smoothing length is computed with the maximum of intial interparticle distance per part. For each SPH part h is computed for all particles of the part as the maximum over all particles of the part of the distance to the closest neighbor multiply by the scale factor hcst:
- The kinetic energy absorbed by conservative smoothing of velocities is output as hourglass energy into /TH/PART files.
- If
is not equal to zero, an artificial stress is
added to solve the tensile instability, proposed by:
J.J. Monaghan, SPH without a Tensile Instability, Journal of Computational Physics, vol. 159, pp. 290-311, 2000
A value of is recommended.
- If the
sphpart_ID is used with Sol2SPH option,
(in /PROP/SOLID),
must be input. The mass of the particle can be
0.0 (it is automatically calculated by Radioss). A
good value of the smoothing length is:Where,
- Smoothing length
- Size of the brick elements
- Number of particle per direction for each solid element
- The smoothing length on
each particle is updated during the computation according to the change in the
volume.
If h_1D = 0, the change in the volume is based on three dimensions:
If h_1D = 1, the change in the volume is based on one dimension:
If h_1D = 2, the smoothing length is kept constant during the computation.
If h_1D = 3, the evolution of h is similar to h_1D = 0 with a 3D evolution of the volume but the evolution of h is bounded so that:
- The particle mass is used only if the mass is not defined in the particle element (/SPHCEL).
