/INTER/LAGMUL/TYPE2
Block Format Keyword Describes the Lagrange multiplier interface TYPE2.
If the Lagrange multiplier formulation is used:
  • The incompatibility with standard kinematic conditions are checked out automatically in Starter
  • Other Lagrange multiplier conditions may be applied to main and secondary nodes, unless there is a physical incompatibility
  • There is no added mass on main node
  • Kinematic conditions are applied to secondary and main nodes
/INTER/LAGMUL/TYPE2/inter_ID/unit_ID
inter_title
grnd_IDs surf_IDm Isearch dsearch
Definition
inter_ID Interface identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
inter_title Interface title.
grnd_IDs Secondary nodes group identifier.
(Integer)
surf_IDm Main surface identifier.
(Integer)
Isearch Search formulation flag for the closest main segment.
= 0 (Default)
Set to 2.
= 1
Old formulation.
= 2
New improved formulation.
(Integer)
dsearch Distance for searching closest main segment.
Default is the average size of the main segments.
(Real)
[ m ]
  1. The dsearch is computed as:
    d search = 1 n ∑ i = 1 n d i
