Block Format Keyword This interface simulates impact between external
surfaces of two brick groups. The external surfaces can only be 16-node thick shell
(/SHEL16) elements.
A Hertz contact theory is used in this interface. This interface does not use
Lagrange multiplier kinematical conditions and is compatible with all kinematic
conditions. The formulation is like a penalty formulation; but with a physical
penalty stiffness based on Hertz contact theory.Figure 1.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
/INTER/HERTZ/TYPE17/inter_ID/unit_ID
inter_title
grbrc_ID1
grbrc_ID2
Fric
Definition
Field
Contents
SI Unit Example
inter_ID
Interface
identifier.
(Integer, maximum 10 digits)
unit_ID
Unit identifier.
(Integer,
maximum 10 digits)
inter_title
Interface
title.
grbrc_ID1
First brick group
identifier (16-node thick shells group).
(Integer)
grbrc_ID2
Second brick group
(Integer)
Fric
Coulomb
friction.
(Real)
Both surfaces are defined
with two brick IDs and not surface IDs.
