USERWIS Starter Interface Subroutines
- SET_USER_WINDOW_NODES(NODE_ARRAY, NUMBER_OF_NODES)
- Use this routine to the Nodes which will participate to the User Window computation. This call permits SPMD compatibility for user Windows. The node have input deck IDs.
