Engine Subroutine USERWI
This subroutine calculates the internal forces and moments versus the velocity, old forces and moments, and specified variables and parameters.
Arguments
The argument list of
USERWI and its individual arguments and
descriptions
are:C-----------------------------------------------------------------------------------------
SUBROUTINE USERWI(
1 IIN ,IOUT ,NUVAR ,NUVARI ,NUMNOD ,NCYCLE ,
2 LENWA ,IUVAR ,ITAB ,
3 TT ,DT1 ,DT2 ,USREINT,EXWORK ,
4 UVAR ,D ,X ,V ,VR ,MASS ,
5 INER ,STIFN ,STIFR ,A ,AR ,WA )
Definition
| Argument | Format | Description |
IIN |
Integer read only scalar | Input file unit (Engine file). |
IOUT |
Integer read only scalar | Output file unit (output file). |
NUVAR |
Integer read only scalar | Size of user float array. |
NUVARI |
Integer read only scalar | Size of user integer array. |
NUMNOD |
Integer read only scalar | Number of nodes. |
NCYCLE |
Integer read only scalar | Current cycle number. |
IUVAR(NUVARI) |
Integer read write array | An array of size NUVARI. This array contains
user data and variables and is saved on restart file. |
ITAB(NUMNOD) |
Integer read only array | An array of size NUMNOD. This array defines
the node ID versus Radioss internal
node number. |
TT |
Float read only scalar | Current time. |
DT1 |
Float read only scalar | Current time step. |
DT2 |
Float write only scalar | User stability time step. With element time step formulation,
DT2 has to be computed at each
cycle. |
USREINT |
Float read write scalar | User window internal energy. |
EXWORK |
Float read write scalar | External work. Variable can be increased. |
UVAR(NUVAR) |
Float read-write array | An array of size NUVAR. This array contains
D(3,NUMNOD) |
Float read only array | Nodal displacements. |
X(3,NUMNOD) |
Float read only array | Nodal coordinates. |
V(3,NUMNOD) |
Float read only array | Nodal initial velocities. |
VR(3,NUMNOD) |
Float read only array | Nodal mass. |
INER(NUMNOD) |
Float read only array | Nodal spherical inertia. |
STIFEN(NUMNOD) |
Float read write array | Nodal stiffness for nodal time step formulation. The added
user stiffness has to be added to
STIFEN. |
STIFR(NUMNOD) |
Float read write array | Nodal rotational stiffness for nodal time step formulation.
The added user stiffness has to be added to
STIFR. |
A(3,NUMNOD) |
Float read write array | Nodal forces. User forces have to be added to
A. |
AR(3,NUMNOD) |
Float read write array | Nodal moments. User moments have to be added to
AR. |
