Generate Radioss User Libraries
Radioss user libraries are built on Windows and Linux with two different compilers: Intel Fortran or Gfortran.
Radioss UserLib SDK Overview
The Radioss user libraries are built on Windows X86-64, Linux X86-64 and Arm64.
├── linux64_intel : Linux X86-64 with Intel compiler 2020.4
├── linux64_sp_intel : Linux X86-64 Single Precision with INTEL Compiler 2020.4 or Higher
├── linuxa64_armflang : Linux Arm64 with armflang 22.1 or higher
├── linuxa64_sp_armflang : Linux Arm64 Single Precision with armflang 22.1 or higher
├── win64_intel : Windows 64 Bits with INTEL Compiler 2020.4 /
| Microsoft Visual Studio 2019 or higher
├── win64_sp_intel : Windows 64 Bits Single Precision
| with INTEL Compiler 2020.4.1 / Microsoft Visual Studio 2019 or higherGfortran versions for Linux X86-64, Linux Arm64, and Windows X86-64 can be found at https://github.com/OpenRadioss/Tools.
Each directory contains a static library and a build script.
Prerequisites
OS Version
The recommended operating system is the same as the recommended operating system for Altair HyperWorks.
Compiler
- Intel Compiler for Linux and Windows
- Install Intel Compiler 2020.4 or higher. Refer to Intel
installation instructions.
Intel Compiler 2020.4 requires Microsoft Visual Studio 2019 or higher.
- More information can be found at https://software.intel.com/en-us/fortran-compilers.
UserLib SDK Installation
SDK Location
The Radioss UserLib SDK is shipped in Altair HyperWorks installation and located in %ALTAIR_HOME%/hwsolvers/radioss/userlib_sdk
If you received the SDK in a separate package, copy it in your target directory.
Environment Variable Settings
RAD_USERLIB_SDK_PATH: PATH to SDK ROOTThe following examples were installed with Altair HyperWorks andALTAIR_HOMEenvironment variable set.- Linux (bash):
export RAD_USERLIB_SDK_PATH=$ALTAIR_HOME/hwsolvers/radioss/userlib_sdk - Windows:
set RAD_USERLIB_SDK_PATH=%ALTAIR_HOME%\hwsolvers\radioss\userlib_sdk
- Linux (bash):
The target Architecture Windows/Linux compiler flavorRAD_USERLIB_ARCH- Linux
(bash):
export RAD_USERLIB_ARCH=linux64_intel
- Linux
(bash):
Generate a Dynamic Library Using the Build Script
Each UserLib version has its own script.
userlib_sdk
├── linux64_intel : build_userlib.bash
├── linux64_sp_intel : build_userlib.bash
├── linuxa64_armflang : build_userlib.bash
├── linux64_sp_armflang : build_userlib.bash
├── win64_intel : build_userlib.bat
└── win64_sp_intel : build_userlib.bat
Window Scripts
Scripts
All scripts have command line arguments to permit the library generation. Their functionality are the same. Although, the syntax between the Linux and Windows scripts are different.
** Generating Radioss Dynamic User Library **
build_userlib_win64.bat /STARTER "Starter source files" /ENGINE "Engine Source files" /LIBRARY "additional static Library" /OUTFILE Library_name [Optional Argument]
[Optional Argument]
/FREE : Source code is in Fortran 90 Free Format
/ADDFLAG "Additional compiler Flags" : Additional compiler flags to set
/LINK_FLAGS "Additional link flags" : add link Flags like library files to link with.- Script
- Description
- /STARTER
- Starter source files. Add these files in quotation marks.
- /ENGINE
- Engine source files. Add these files in quotation marks.
- /LIBRARY
- Optional. Additional static library for link.
- /OUTFILE
- Optional. A specified library name other than the default.
- /FREE
- Optional. Use this if source code is written in Fortran 95 Free Format.
- /ADDFLAG
- Optional. Use this to set additional compiler flags. Add flags in quotation marks.
- /LINK_FLAGS
- Optional. Advanced users only. Use this to add additional link flags or 3rd party libraries during the dynamic libraries creation phase.
Compiling LAW29 for shells (LECM29.F and SIGEPS29C.F) and Generating a Library with Default Name
F:\>%RAD_USERLIB_SDK_PATH%\%RAD_USERLIB_ARCH%\build_userlib.bat /STARTER "lecm29.F" /ENGINE "sigeps29c.F"
F:\>echo off
Preparing Library
Compiling: lecm29.F
lecm29.F
Compiling: sigeps29c.F
sigeps29c.F
Creating library: libraduser_win64.dll
Creating library libraduser_win64.lib
Creating object libraduser_win64.dll
Done
F:\>
Linux Scripts
Scripts
** Generating Radioss Dynamic user library **
Script Usage
build_userlib.sh starter="Starter source files" engine="Engine Source files" library="Additional static Library" outfile="Optional library name" [Optional Arguments]
-free : Source files are in Fortran 90 Free Format
-addflag "Additional Compiling Arguments" - Advanced Users Only
-link_flags "Additional Linking Arguments" - Advanced Users Only
- Script
- Description
- starter
- Starter source files. Add quotation marks if more than one file is set.
- engine
- Engine source files. Add quotation marks if more than one file is set.
- library
- outfile
- -free
- Use this option if source code is written in Fortran 95 Free Format.
- -addflag””
- Advanced user only. Use this to set additional compiler flags. Add flags in quotation marks.
- -link_flags=“ “
- Advanced users only. Use this to add additional link flags or 3rd party libraries during the dynamic libraries creation phase.
neo DDS/LOI29> $RAD_USERLIB_SDK_PATH/$RAD_USERLIB_ARCH/build_userlib.bash starter="lecm29.F" engine="sigeps29c.F"
Compiling: lecm29.F
Creating library: libraduser_linux64.so
Done
Generated Library Name
In Windows, the default generated library is named libraduser_win64.dll if /OUTFILE “Alternate library name” is not set.
In Linux, the default generated library is named libraduser_linux64.so if outfile=”Alternate library name” is not set.
Load the User Library
When using the alternate library
name option, use –dylib [library name] command line argument in
Starter or Engine subroutines to load the library.
-dylib [alternate library name]command line argument.- If RAD_USERLIB_LIBPATH is set, load libraduser_win64.dll or libraduser_linux64.so in the directory defined in this environment variable.
- Load libraduser_win64.dll or libraduser_linux64.so in the local execution directory.
- Load libraduser_win64.dll or libraduser_linux64.so using the %PATH% environment variable (Windows) or $LD_LIBRARY_PATH environment variable (Linux).
A message is printed in the output files when the library is successfully loaded.
EXTERNAL LIBRARY FOR USERS CODE INTERFACE
LIBRARY NAME . . . . . . . . . . . . . . . . . . . . libraduser_win64.dll
Altair Radioss USERS CODE INTERFACE VERSION . . . . . . . .1301504220When user options are used in the Radioss Input Deck, the code in the user library is used.
