Starter Subroutine USERWIS_INI
This subroutine reads input data and prepares the Radioss buffers for allocation.
Arguments
USERWIS
and its individual arguments and
descriptions
are:C-----------------------------------------------------------------------------------------
SUBROUTINE USERWIS_INI(
. IIN ,IOUT ,IUPARAM ,NUMNOD ,ITAB ,
. X ,V ,VR ,MASS ,INER ,
. NUVAR ,NUVARI )
Definition
Argument | Format | Description |
IIN |
Integer read only scalar | Input file unit (Starter input file) on which the data are read. |
IOUT |
Integer read only scalar | Output file unit (Starter output file). |
IUPARAM(*) |
Integer array | Parameters to be transferred to Radioss. |
NUMNOD |
Integer scale | Number of nodes (defined by /NODE option). |
ITAB(NUMNOD) |
Integer array | An array of size NUMNOD . This defines the
node ID versus Radioss internal node
number. |
X(3,NUMNOD) |
Float array | Nodal coordinates. |
V(3,NUMNOD) |
Float array | Nodal initial velocities. |
VR(3,NUMNOD) |
Float array | Nodal initial rotational velocities. |
MASS(NUMNOD) |
Float array | Nodal mass. |
INER(NUMNOD) |
Float array | Nodal spherical inertia. |
NUVAR |
Integer scalar | Size of global user’s float array. Memory size available for float. |
NUVARI |
Integer scale | Size of global user’s integer array. Memory size available for integer. |
