Starter Subroutine USERWIS
This subroutine reads the input data.
You can specify the number of cards and their format.
Arguments
USERWIS
and its individual arguments and
descriptions
are:C-----------------------------------------------------------------------------------------
SUBROUTINE USERWIS(IIN ,IOUT ,NUMNOD ,ITAB ,
. X ,V ,VR ,MASS ,INER ,
. NUVAR ,NUVARI ,UVAR ,IUVAR )
Definition
Argument | Format | Description |
IIN |
Integer read only scalar | Input file unit (Starter input file) on which the data are read. |
IOUT |
Integer read only scalar | Output file unit (Starter output file). |
NUMNOD |
Integer scalar | Number of nodes (defined with /NODE option). |
ITAB(NUMNOD) |
Integer array | An array of size NUMNOD . This defines the
node ID versus Radioss internal node
number. |
X(3,NUMNOD) |
Float array | Nodal coordinates. |
V(3,NUMNOD) |
Float array | Nodal initial coordinates. |
VR(3,NUMNOD) |
Float array | Nodal initial rotational velocities. |
Mass(NUMNOD) |
Float array | Nodal mass. |
INTER(NUMNOD) |
Float array | Nodal spherical inertia. |
NUVAR |
Integer scalar | Needed size of global user float array. |
NUVARI |
Integer scalar | Needed size of global user integer array. |
UVAR(MAXNUVAR) |
Float array | An array of size MAXNUVAR in Radioss Starter. This array is
transmitted via the restart file to Radioss Engine, where it has a size of
NUVAR . |
IUVAR(MAXNUVARI) | Integer array | An array of size MAXNUVARI in Radioss Starter. This array is
NUVARI . |
