/FRAME/NOD
Block Format Keyword Describes the node defined moving frame.
| /FRAME/NOD/frame_ID | |||||||||
| frame_title | |||||||||
| node_ID1 | node_ID2 | node_ID3 | |||||||
| X1 | Y1 | Z1 | |||||||
| X2 | Y2 | Z2 | |||||||
Definition
| frame_ID | Reference frame
identifier. (Integer, maximum 10 digits) |
| frame_title | Reference frame
title. (Character, maximum 100 characters) |
| node_ID1 | Node identifier
N1. (Integer) |
| node_ID2 | Node identifier
N2. (Integer) |
| node_ID3 | Node identifier
N3. (Integer) |
| X1 | X component of frame axis
. (Real) |
| Y1 | Y component of frame axis
. (Real) |
| Z1 | Z component of frame axis
. (Real) |
| X2 | X component of axis
. (Real) |
| Y2 | Y component of axis
. (Real) |
| Z2 | Z component of axis
. (Real) |
- If node_ID2 = 0 or node_ID3 = 0, Lines 4 and 5 are read.
- If node_ID2 ≠ 0 and node_ID3 ≠ 0, the frame is defined by three nodes like a moving frame. It is strictly attached to node_ID1 as its origin.
- If node_ID2 = 0 and node_ID3 = 0, the frame is defined by node_ID1 and its orientation is defined by two vectors ( and ), like a fixed frame.
- The frame translation and rotation depend only on the displacement and orientation of node_ID1.
