/ALE/GRID/SPRING
Engine Keyword With this keyword it is possible to modify grid formulation parameters which initially be set in Starter keyword /ALE/GRID/SPRING. (Altair bar method for grid velocity computation).
/ALE/GRID/SPRING
Δ t 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads hadaWgaaWcbaGaaGimaaqabaaaaa@38EF@ γ η υ Vmin
Definition
Δ t 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads hadaWgaaWcbaGaaGimaaqabaaaaa@38EF@ Typical time step.
(Real)
[ s ]
γ Nonlinearity factor.
Range: [0;1]
(Real)
η Damping coefficient.
(Real)
υ Shear scale factor.
(Real)
Vmin Minimum volume for element deletion.
(Real)
[ m 3 ]
  1. For more details, refer to ALE Grid Calculation in the User Guide and /ALE/GRID/SPRING in the Reference Guide.
    As of v12.0.210, /ALE/2 was replaced by /ALE/GRID/SPRING.
  2. The Δ t 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads hadaWgaaWcbaGaaGimaaqabaaaaa@38EF@ must be greater than the actual time step used in simulation.
  3. The γ is used to prevent the time step from dropping due to element collapse.
    γ = 1 means no nonlinear effects
    0 < γ < 1 means less weight is given to elements that do not collapse.
  4. Default values are taken from a previous run.
  5. This option is not available when /ALE/GRID/ZERO is initially set in the model.
