/ALE/GRID/DISP
Engine Keyword With this keyword it is possible to modify grid formulation parameters, which initially was set in Starter keyword /ALE/GRID/DISP. (Altair average displacement grid formulation).
/ALE/GRID/DISP
Umax Vmin
Definition
Umax Maximum absolute grid velocity.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
Vmin Elements with a volume less than Vmin will be deleted.
(Real)
[ m 3 ]
  1. For more details, refer to ALE Grid Calculation in the User Guide and /ALE/GRID/DISP in the Reference Guide.
  2. Default values are taken from a previous run.
  3. This option is not available when /ALE/GRID/ZERO is initially set in the model.
