2025.1
Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
View new features for Radioss 2025.1.
Current Radioss format uses the 12x extension format.
Engine Keyword Dynamic relaxation with auto-defined adaptive damping.
Engine Keyword Dynamic relaxation with auto-defined adaptive damping applied to node group grnd_ID.
Engine Keyword Used to modify the Rayleigh mass and stiffness damping coefficients defined using the Starter /DAMP option.
Engine Keyword Dynamic relaxation.
Engine Keyword Dynamic relaxation applied to node group identifier grnd_ID.
Engine Keyword Kinetic energy relaxation.
Engine Keyword Kinetic energy relaxation applied to node group grnd_ID.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, and so on) in a state file (STA-File).
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
