/ALE/GRID/DONEA
Engine Keyword With this keyword it is possible to modify grid formulation parameters, which initially were set in Starter keyword /ALE/GRID/DONEA.
/ALE/GRID/DONEA
α γ Fscalex Fscaley Fscalez Vmin
Definition
α Coefficient in DONEA's formula for grid velocity calculation.
(Real)
γ Grid velocity limitation factor W < γ < V.
(Real)
Fscalex X grid velocity scale factor.
(Real)
Fscaley Y grid velocity scale factor.
(Real)
Fscalez Z grid velocity scale factor.
(Real)
Vmin Minimum volume for element deletion.
(Real)
[ m 3 ]
  1. For more details, refer to ALE Grid Calculation in the User Guide and /ALE/GRID/DONEA in the Reference Guide.
    As of v12.0.210, /ALE/0 was replaced by /ALE/GRID/DONEA.
  2. Default values are taken from a previous run.
  3. This option is not available when /ALE/GRID/ZERO is initially set in the model.
