This tutorial demonstrates a phone drop test simulation using Explicit Analysis in
OptiStruct when the phone is dropped on the floor with a
velocity of 5425 mm/s.
Before you begin, copy the file(s) used in this tutorial to your
working directory.
Figure 1 illustrates the structural model used for this
tutorial. The phone and its parts are considered in this model. The phone is dropped
on the floor at a velocity of 5425 mm/s.Figure 1. Model and Loading Description
Launch HyperMesh and Set the OptiStruct User Profile
Launch HyperMesh.
The User Profile dialog opens.
Select OptiStruct and click
OK.
This loads the user profile. It includes the appropriate template, macro
menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for
OptiStruct.
Open the Model
Click File > Open > Model.
Select the Drop_test_phone.hm file you saved to
your working directory.
Click Open.
The Drop_test_phone.hm database is loaded
into the current HyperMesh session, replacing any
existing data.
Apply Loads and Boundary Conditions
Create TSTEPE Load Collector
The time-step control parameters for explicit analysis is defined.
In the Model Browser, right-click and select Create > Load Collector.
For Name, enter TSTEPE.
For Card image, select TSTEPE.
For TYPE, select ELEM.
for DTFAC, enter 0.9.
Create SPC Load Collector
In this step, Single Point Constraints (SPCs) is used to fix the floor.
For Name, enter SPC.
From the main menu, click BCs > Create > Constraints to open the Constraints panel.
Select the independent node of the RBE2 element and select all DOFs (1 through
6), and enter a value of 0 (all the DOFs are
fixed).
Figure 2. Definition of SPC on the selected node Figure 3. SPC applied to for floor
Click Create > return.
Create NLOUT Load Step Input
In the Model Browser, right-click and select Create > Load Step Inputs.
For Name, enter NLOUT.
For Config type, select Output parameter from the
drop-down menu.
Note: The default is NLOUT.
Activate NINT, then for VALUE, enter 30.
Figure 4. NLOUT Definition
Create INI_VEL Load Collector
In this step, an initial velocity of 5425 mm/s will be applied to the phone in the
negative Z direction.
For Name, enter INI_VEL.
Click BCs > Create > Constraints to open the Constraints panel.
Activate the create radio button.
Toggle to nodes and click on
nodes and select by
sets.
Select phone_nodes set and click
select.
This Set is already created in the model.
For load types =, select TIC(V).
Activate only dof3 and enter
-5425.0.
Figure 5. Definition of Initial Velocity
Create Explicit Load Step
In this step, an explicit load step will be created, where the previously defined
load collectors and load step input will be referenced.
In the Model Browser, right-click and select Create > Load Step.
For Name, enter phone_drop.
Under Subcase Definition, Analysis type, select
Explicit.
For SPC, select the SPC load collector and click
OK.
For TSTEPE, select the TSTEPE load collector and click
OK.
For TTERM, enter 0.001.
For NLOUT, select the NLOUT load step input and click
OK.
From SUBCASE OPTIONS for IC, select the
INI_VEL load collector and click
OK.
Figure 6. Create Explicit Load Step
Add Control Cards
In this step, control cards for the simulation will be defined.
Select Analysis > control cards.
Click next to advance until
GLOBAL_OUTPUT_REQUEST is available, then click
GLOBAL_OUTPUT_REQUEST.
Activate the CONTF checkbox.
For FORMAT, select H3D.
For OPTION, select ALL.
Activate the DISPLACEMENT checkbox.
Activate the STRESS checkbox.
Activate the STRAIN checkbox.
Figure 7. Definition of Control Cards
Submit the Job
From the Analysis page, click the OptiStruct
panel.
Figure 8. Accessing the OptiStruct Panel
Click save as.
In the Save As dialog, specify the location to write the
OptiStruct model file and enter
Drop_test.fem for the filename.
For OptiStruct input decks,
.fem is the recommended extension.
Click save.
The input file field displays the filename and location specified in the
save As dialog.
Set export options to all.
Set run options to analysis.
Set memory options to memory default.
Click OptiStruct to launch
the OptiStruct job.
If the job is successful, new results files
should be in the directory where the Drop_test.fem was written. The
Drop_test.out file is a good place to look for error messages
that could help debug the input deck if any errors are present.
Review the Results
View a contour plot of stresses and displacement.
From the OptiStruct panel, click HyperView.
HyperView is launched and the results are
loaded. A message window appears to inform of the successful model and result
files loading into HyperView.
Go to the Results tab.
On the Results toolbar, click to open the
Contour panel.
Set Result type to Displacement and click on
Apply to contour the elements.
Figure 9. Set Displacement as Result Type
The contour of displacement plot is observed at the final increment.Figure 10. Displacement Contour
