In the New Session window, select HyperMesh from the list of tools.
For Profile, select OptiStruct.
Click Create Session.
Figure 1. Create New Session This loads the user profile, including the appropriate template, menus,
and functionalities of HyperMesh relevant for
generating models for OptiStruct.
Import the Model
On the menu bar, select File > Import > Solver Deck.
In the Import File window, navigate to and select
airframe_section_CMS.fem you saved to your
working directory.
Click Open.
In the Solver Import Options dialog, ensure the Reader is
set to OptiStruct.
Figure 2. Import Base Model in HyperMesh
Accept the default settings and click Import.
Submit the Residual Job
From the menu bar, select
Analyze.
On the Analyze ribbon, under the Analyze tool group, select Run
OptiStruct Solver.
The panel area opens.
Click Save as.
For File name, enter
airframe_section_BASELINE_CMS.fem.
The .fem extension is necessary to recognize this as an
input file.
Click Save.
Set export options: to all and click
Export.
Set run options: to analysis.
Click Run.
If the job is successful, new results files appear in the directory
where Altair HyperWorks was invoked. The
airframe_section_BASELINE_CMS.out file is a good place
to look for error messages to help debug the input deck if any errors are
present.
