Altair HyperMesh
New Features
- New context support for creating rigids and RBE3s.
Enhancements
- The pre-tension section in a group entity now allows you to select and define a follower load option.
- A new model checker has been added to detect long names (beyond 80 characters) for solver-named entities.
- Introduced the selection of a property when creating a set segment with *SURFACE, TYPE=ELEMENT. This allows you to create set segments based on the element set used for property definition.
Resolved Issues
- The Entity Editor has been improved for the Abaqus beam element.
- The Surface Interaction keyword is no longer visible in the Property entity for Abaqus/explicit.
- Set segment normal was reversed upon Import/Export in the Abaqus 2D profile.
- Transformation of a nodal DOF using sets now works properly.
- Issue with the API not creating a distribution table and orientation.
