Altair HyperStudy 2026 Release Notes
New Features
Inspire Model
Seamless integration into advanced geometry modeling and a fast analysis environment.
Spice Model
A new model type to integrate electronic circuit board simulations. Any solver type with netlist file (*.net, *.cir) support, such as LTspice, Ngspice, and HyperSpice, can be executed.
Have Your Own Way of Visualizing Data via Plotly
Python-based custom plotting can now be integrated as an option in the post-processing area.
Onboarding Custom Distribution Schemes
Reliability-based studies now support user-defined distribution types.
Perform Reliability Assessment Based on Optimum Values
A shortcut button has been added to the post-processing step of Optimization, DOE, Fit, and Sampling Fit approaches to effortlessly create a Stochastic Approach, which bases the expected input values on the selected run.
Enhancements
  • The definition of distributions has been restructured to make it more user-friendly, and the Distribution Role has been completely removed.
  • A progress bar has been introduced to track the progress during the apply-specification stage.
  • External algorithms are now registered under the same option, Register External Algorithm.
  • Via the Python API, each task can be performed per model (write and execute) or response (extract) independently.
Resolved Issues
  • Dark mode GUI issues.
  • FMI model did not support string variables.
  • Some tutorials were missing in the Tutorials tab.
  • Unable to display files in the PhysicsAI ribbon.
Announcements
  • The Hstp Data Source tool will be removed in version 2026.1.
  • The Python API module, alt.hst.postprocessing.hstdataset, has been deprecated and replaced with alt.hst.api.dataset.
