Post-Processing
New Features
Provide capability to compute 3D hydrodynamic acoustic map in GSP tool
Provides the capability to compute three-dimensional hydrodynamic acoustic maps from the GSP tool. The existing GSP functionality is primarily focused on surface data and computation of SPL (dB), this improvement seeks to extend it to handle volumetric pressure or velocity data to compute the power spectrum.
Add "Export" option for time-dependent data
Provides the addition of an "Export" option for time-dependent data in HMCFD written to VTKHDF. This feature enables users to create an extract database from transient datasets, which can be loaded separately for faster interaction and manipulation.
ISO standard center frequency for octave and fractional octave output
Modifies the center/min and max frequencies for GSP when band type is octave or fractional octave. ISO standards have been applied to HyperMesh aeroacoustics results output.
Add supported files from Import / Open
Provides the addition of VTKHDF (.series) and Ensight Gold result files to the list of supported file types by group for results import.
Resolved Issues
  • Export to h3d when time-dependent data is loaded now retains correct timestep data and range
  • HMCFD Report: Streamlines, seed_type=rectangular has been updated to include each cartesian direction
  • Session no longer crashes when loading specific .h3d file created by Physics AI
  • AcuSolve Log Reader options with “Derived Quantity Output” no longer gives active exception when results are not available
