Highlights
HyperMesh CFD 2025 introduces the following new features:
Geometric Modeling:
  • Support of all critical discrete, Geometry ribbons tools in template manager
Case Setup (External Aerodynamics):
  • Ground patch visualization
Post-Processing:
  • 3D hydrodynamic acoustic map computation in the GSP tool
  • Export option for time-dependent data written to VTKHDF
  • ISO standard center frequency for octave and fractional octave output
  • Additional supported files from the Import/Open menu
General resolved issues:
  • Crash on loading HyperMesh CFD if admin installed
  • Template manager dialog closed when pressing esc on operation definition dialog
  • View toolbar was not visible on opening session
  • File > Save not working if changes were made in case setup
