Case Setup
New Features
- Ground patch visualization
 - The ground patch around the vehicle is now graphically displayed on the wind tunnel floor when the “Enable ground patch” option is enabled.
Resolved Issues
- XML issues:
- Turbulence offset was not editable
 - Wheels were misidentified as body parts
 - Merge output files option was written incorrectly
 - Attribute sync issues:
- Mesh refinement for OSM/MRF volumes should be in sync with property editor
 - Scaling factor gets reset on closing run dialog
 - Fan can be accidentally setup twice leading to mismatch in properties when reset to body
 - Number of layers in offset refinement is not refreshed
 - Visibility of turbulence source without mesh control is reset
 - Virtual fan coefficients get reset without enter key
 - Multiple database imports no longer create multiple wind tunnels
 - Warning added when deleting run from run dialog
 - Fixed segmentation errors:
- On fan axis reset using axis buttons
 - Fan axis reset on tab/enter keys
 - On selecting “Identify” part as body
