2026
Administrative tools to customize your Altair HyperWorks installation.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
View new features for Altair HyperWorks 2026.
Quick introduction to Altair HyperWorks products.
Discover the functionality of Altair HyperWorks products with interactive tutorials.
Use the Altair License Utility to determine a managed Altair Licensing ID, check license usage, borrow licenses, and set up managed Altair Units.
Altair Compute Console (ACC) is a utility that allows you to start different Altair HyperWorks Solvers.
Remote Job Submission in Altair Compute Console (ACC) is implemented as an alternative to a local run.
AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2020 (or earlier) to Abaqus 2025.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF).
HvTrans is a result translator for HyperView that translates solver result files to .h3d files.
The HWTK GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HWTK GUI Toolkit commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Cleanup Utility is a script for Windows that removes any custom settings that you may have due to the Altair applications installed.
The Model Identification Tool (MIT) is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The MIT operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
Changes the formulation for displayed components to the desired value if required.
Applies velocity to an HWAT assembly.
Creates an accelerometer and supporting entities.
Scans the model and creates arrays that are required by the dummy positioning APIs.
Creates a finite rigid wall.
Creates a infinite rigid wall.
Creates a rigid pole.
Creates a rigid wall in HyperMesh.
Creates accelerometer data for import.
Finds the stop angles of the component.
This function examines the component name and title card for a sub-string match to the given assembly name. If a match is found, this component is added to a newly created assembly with the same name given in the list.
Checks to see if the given element belongs to a rigid part.
Copies an element to a part with MAT20 material.
Creates a new shell property for the accelerometer.
These functions use a SAX-based parser.
These are primarily private functions, and are not called directly in most cases. They are usually called privately by other functions as helpers.
The H3D Validation Tools available are H3D Info and H3D Validate.
Use the Altair HyperWorks Products Uninstaller to remove all files from the installation directory.
