Integrated Diagnostics - Study
Perform a partial sum response study by excluding the contributions from the selected contributors. The list of contributors available depends on the diagnostics done prior to selecting the Study tab.
Subcase
From the drop-down menu, select the subcase to study.
  • The RPM subcase for the powertrain use case.
  • The wheel subcase for the road use case.
Response
Select the response to study.
Frequency range
Indicates the available range, based on your PFMODE.PCH or .f06 file.
% to Exclude
Optional field that allows you to exclude a percentage of the contributors from the response.
Select contributor(s) to:
Select the contributors that you want to exclude in the response study. The list of contributors available depends on the diagnostics performed.
  • Click to select the entire list of contributors.
  • Click to deselect your current selections.
  • Click to exchange the currently selected contributors for the unselected contributors in the list.
Export Study Data
Exports a *.pch file with the modified response after the study.
Display Options
Launches the Display Options dialog, which allows you to further customize the plot.
Display
Displays the response study plot once your selections are complete.
Figure 1. Response study plots
