Flow Induced Noise/General Signal Processing
The General Signal Processing utility processes the time domain pressure results from CFD simulations and visualizes the results in both the time and frequency domain.
Probes and surface input are supported.
- For probe input, use the utility to generate frequency response curves.
- For surface input, use the utility to generate the dB maps' contour and frequency filtered transient animation.
