Integrated Diagnostics - Loadcase Processing
Load the sensitivity and force results from an OptiStruct *.pch or Nastran *.pch file to calculate the vehicle responses.
- File selection
- Select the following file types:
- Transfer Function
- Select an OptiStruct or Nastran *.pch file, which contains transfer function output data.
- Force
- Select an OptiStruct or Nastran *.pch file, which contains force output data, then click Load.
- Calculate and Export Forces
- Calculates the vehicle response using the selected transfer and force files and exports the data into a PCH file. This PCH file is loaded in the Vehicle Response tab.
- TF Tab
- Review the TF options.
- Subcase ID
- Select a transfer function subcase from the drop-down menu.
- TF Type
- Select the transfer function type depending on the response type, pressure, velocity, acceleration.
- Response ID
- Select the grid ID of the response from the drop-down menu.
- Component
- Select the component of response grid ID from the drop-down menu.
- Display Options
- Customize the response plot, including scale, weighting, and the plot layout.
- View TF
- Once the result selection options are complete, select View TF to display the TF data.
- Force Tab
- Review the forces.
- Subcase ID
- Subcase Label
- Enter the subcase label.
- Grid ID
- Select the grid ID of the force output from the drop-down menu.
- Component
- Select the component of force grid ID from the drop-down menu.
- Display Options
- View Force
- Coherence On/Off Parameters
- Coherence Threshold Frequency
- Specify the threshold frequency for coherence.
- Wheelbase
- The wheelbase to be used for the calculation; the value is taken from the result file.
- Vehicle Speed
- The vehicle speed to be used for the calculation; the value is taken from the result file.
