Summary Post Processing
View summary of run data.
View Run Data Summary
View a detailed summary of all input variable and output response run data in a tabular format from the Summary post processingEvaluation Data tab.
- From the Evaluate step, click the Evaluation Data tab.
 - From the Post Processing step, click the Summary tab.
 - From the Channel selector, select the channels to display in the summary table.
 - Analyze the run data summary.
 - Optional:
                Disable run data from post processing without deleting it entirely from the
                    study by clearing a run's corresponding checkbox in the Post Process
                    column.
                When a run is disabled, it will be removed from all plots, tables, and calculations in the Post Processing step.
