Evaluates all possible combinations of input variable levels. This
will resolve all the effects and interactions.
Table 1 shows a Full Factorial run matrix for a three
variable problem (variables A and B have two levels and variable C has three
levels).
Table 1.
Run Number
A
B
C
1
1
1
1
2
1
1
2
3
1
1
3
4
1
2
1
5
1
2
2
6
1
2
3
7
2
1
1
8
2
1
2
9
2
1
3
10
2
2
1
11
2
2
2
12
2
2
3
Usability Characteristics
For a case with k input variables, each at L levels, a
Full Factorial design has L^k runs. For studies with
a large number of input variables and levels, the total
number of runs is larger. For example, for a study with eight factors and
each with three levels, 6561 runs are needed (3^8 = 6561).
This method may be practical for studies where there is a small number of
variables and each variable has two levels, such as yes or no; -1 or 1. This
method is not practical for most CAE applications where there are many
factors possibly at several levels, and the simulations are costly.
If the number of levels is not equal across variables, then the total number
of runs is calculated by the product of the L^k terms. For example, consider
eight variables: five variables with two levels, two variables with three
levels and one variable with four levels. The number of full factorial runs
is 1152 = 2^5 * 3^2 * 4^1.
Any data in the inclusion matrix is combined with the run data for
post-processing. Any run matrix point which is already part of the inclusion
data will not be rerun.
When the number of levels is less than the defined number of states of a
discrete or categorical variable, the assigned levels are based on an
equally spaced sample of the ordinal indices.
Settings
In the Specifications step, Settings tab, change method
settings.
Parameter
Default
Range
Number of Runs
2-1,000,000
Number of new designs to
be evaluated. is the number of input variables with i levels. This number is
determined automatically based on the number of input variables and levels.
Use Inclusion
Matrix
Off
Off or On
Concatenation without
duplication between the inclusion and the generated run matrix.
