Edit the Run Matrix
Edit the summary of run data stored in the run matrix by editing existing runs or adding new run data.
Edit Run Data
Manually edit existing run data in the Run Matrix.
In the Specifications step, click
.The Edit Data Summary dialog opens.
- Enter new values in each cell, as necessary.
Add Run Data
Manually enter new run data in the Run Matrix.
- Click Add Run.
Enter run data.
- Manually enter run data.
- Copy and paste run data into the run matrix.
Example: Copy run data from a spreadsheet, then highlight and right-click on the new runs you added in the Edit Data Summary dialog and select Paste from the context menu.
Tip: Add multiple runs simultaneously by left-clicking and holding the mouse
button on Add Runs. In the pop-up, enter the number of runs
to add and press Enter.
Import Run Data
Import run data into the run matrix from a plain text file, an approaches' evaluation data, or from a HyperStudy post processing file.
Click Import Values.
The Import Values dialog opens.
- Select a source type.
- Click Next.
Select the source that contains run data.
- For Plain Text File, select the source file and delimiter type, and select whether or not the columns in the source file have labels. Optionally, specify the rows to import by entering the start and end row.
- For Approach evaluation data, select the approach that contains run data.
- For HyperStudy post processing file, select the source file.
- Click Next.
Define the variable to column assignment(s).
- From the Variable to Column Assignment table, select a variable to which run data will be assigned.
- From the Columns in Source File table, select the column that contains run data to assign to the selected variable.
- Click Assign.
- Click Finish.
