Export Files
Export the current contour result file.
- From the menu bar, select .
                In the Export H3D Model dialog, enter a file name and then
                    click
 and browse to your working
                    directory.
                Define any export options and then click OK.
                Currently, only static FE result files, not fatigue result files, are supported.
