Open Files
Open a file.
The directory where file dialogs are opened is saved from the previous successful
dialog operation. For example, if you select a file in
C:\my_files, the next time a file dialog is opened, it will
open in C:\my_files. There are a few exceptions:
- If the dialog is associated to a filename entry box, the directory is taken from the path entered in the entry box, instead of using the saved directory.
- Certain dialogs take you to a directory in the installation where the selection would commonly be made, instead of using the saved directory.
- If the directory is not valid, the file dialog opens in the application start-in directory.
Open a file one of the following ways:
- From the Home tools, Files tool group, click the Open Model tool.
Figure 1. - From the menu bar, select .
In the Load model and result dialog, browse for and select
a model file and a result file.
If opening a previous session, use the Open File dialog to select an .hlf file.
- Click Apply/Open.
Tip: Quickly open an .h3d file by
dragging-and-dropping it from a file browser into the modeling window.
