H3D Model Export Options
Options used when exporting models
- Compression Maximum % loss
 - Suggested amount that the model's values can be perturbed when compressed. The value you provide will be compared to the results of an error estimation function to allow your compression algorithm to maintain an acceptable level of accuracy for your data. However, even a percentage of zero may result in some loss due to minute rounding errors.
 - All models
 - Export all the models in the window to individual files when two or more models are loaded.
 - Entity attributes
 - Output specific attributes assigned to the model's entities, such as color and transparency. If deselected, the default attributes will be used when the file is loaded.
 - Include Masked Elements
 - Export all masked elements with the model.
 - Animation
 - Export any animation settings applied.
 - Include sets
 - Export all sets with the model.
 - Results
 - Export result values with the model. If not selected, only the model and animation are exported.
 - View Attributes
 - Output all attributes assigned to the model during a session. If deselected, the default attributes will be used when the file is loaded.
 - HTML
 - Create an HTML file for use with HyperView Player.
 - Preview Image
 - Export a preview image.
Note: When exporting CFD data to an H3D file:
            - If there is a streamline created for at least one rake, the exported H3D file will contain the datatypes/datasets used by the CFD/Streamlines panel. In addition, all of the rake definitions and streamline settings/display options will also be captured in the H3D file.
 - If there are no streamlines available in the model, the exported H3D file will not contain any datatypes/datasets solely used by the CFD/Streamlines panel. In addition, none of the rake definitions or streamline settings/display options will be captured in the H3D file.
