2026
Explore additional post-processing options related to the input result files.
Explore the various result plotting tools for the imported result files.
View new features for HyperLife 2026.
Discover HyperLife functionality with interactive tutorials.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Set up your model for analysis.
Run the model and view results.
Explode the model and create derived load cases.
Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
View your model in motion using animation controls.
Use the Contour tool to create contour plots of a model and graphically visualize the analysis results.
Use the Iso tool to display single iso values (iso surfaced for solids or iso line for shells) dependent on results data.
Use the Vector tool to set options for a vector plot.
Use the Tensor tool to view tensor plots of stress and strain directions and magnitudes for various solvers from elemental values.
The Edit Legend dialog allows you to change the legend properties.
You can edit the contour, vector, or tensor plot legend in the graphics area.
Results in some analysis types come as complex numbers.
A listing of results that are computed in HyperLife.
The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be bound by same feature angle or face.
Annotate model results using Notes and Measures.
The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperLife.
Create your own user defined coordinate systems or select result coordinate systems.
Explore verification problems for SN and EN with time series loading.
