2026
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
View new features for HyperMesh CFD 2026.
Tutorial Level: Advanced Use HyperMesh CFD to prepare the geometry of a car for an external aerodynamics simulation.
Tutorial Level: Intermediate Use HyperMesh CFD to perform an aerodynamic analysis of a vehicle.
Tutorial Level: Advanced Use HyperMesh CFD to perform an external aerodynamic analysis of a vehicle.
Access industrial application workflows through the Altair community.
Click here to access online training material.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model and run the simulation.
Post-process the simulation results by creating visualizations and measurements.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Automate simulation processes with templates and utility scripts.
More resources for AcuSolve and ultraFluidX solvers.
