2026
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Click here to access online training material.
View new features for HyperMesh CFD 2026.
Access industrial application workflows through the Altair community.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model and run the simulation.
Post-process the simulation results by creating visualizations and measurements.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Automate simulation processes with templates and utility scripts.
More resources for AcuSolve and ultraFluidX solvers.
