Short-circuit curve - Wound field synchronous machines
The aim of the test “Characterization – Short circuit – Generator – Short-Circuit” is to characterize the behavior of the machine when running in a three-phase short-circuit state and to provide the short-circuit curve by considering several field currents.
In such a case, it is recommended to perform a transient computation in Flux® environment. The application “Export to Flux” allows exporting the model with the corresponding scenario ready to be solved
- User inputsThe maximum field current value (or equivalent maximum field current density) and the rotation speed are the only necessary standard input parameters to run this test. The operating temperature of the field winding and damper bars, if existing, can be defined in the settings “Thermal”. Additionally, if the user wants to run a complete short-circuit test for a single point, performing a magneto-transient simulation specified with a field current value, the two concerned inputs are available as standard inputs as well.
- Computation of non-linear behaviorAlthough the short-circuit characteristic is ideally linear, non-linear behavior could become significant if the field current value is high enough, depending on the machine topology. A systematic approach based on small signal modelling is performed to compensate for the linear characteristic with any existing non-linear behavior displayed by the machine according to the maximum field current value provided.
 Characterization - Short circuit – Generator – Short-Circuit - Overview
 Characterization - Short circuit – Generator – Short-circuit – The main outputs
