Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
New material property B(Stress)
New material property B(Stress) for the consideration of magneto-mechanical effects in laminated magnetic non-conduction regions
Introduction
In version 2022.3, Flux can now model the dependency between the B(H) constitutive relation of an electrical steel and a mechanical constraint through a new magneto-mechanical material property B(Stress). This new feature is particularly useful for users interested in modeling the modification of the magnetic properties of materials due to the fabrication process (e.g. punching of laminated steel sheets), which impacts the performance of electrical machines.
Utilisation outline
- the new B(Stress) magneto-mechanical property, given by the saturation magnetostriction constant of the material;
- a B(H) magnetic property of subtype isotropic analytic saturation + knee adjustment (arctg, 3 coef.).
Then, the material must be assigned to a Laminated magnetic non-conducting region. In the region description dialog box, the user must then enable the new option Mechanical stress dependence and choose between two options:
- Uniform over the whole region: useful for describing a region subjected to a uniformly distributed mechanical constraint
- Exponential decay towards region center: useful for describing a mechanical stress distribution that is restricted to the region boundaries, as in the case of steel sheets that were cut through punching.
In both cases, the user must also provide the equivalent uniaxial stress representing the constraint in MPa. Option Exponential decay towards region center also requires informing a distance in millimeters, that caracterizes the exponential decay of the mechanical constraint from the region boundary.
The complete and detailed procedure is presented in the corresponding new chapter of the user guide.
Application example
- Approach based on the constraint Uniform over the whole region: the stator of the PMSM is split in two separate regions. The first is a narrow band corresponding to the edges of the stator and has been damaged by the punching process. The second represents the innermost parts of the stator that have not been damaged through punching.
- Approach based on the Exponential decay towards region center of the constraint: the stator is represented by a single region. The compressive mechanical stress is set to its maximum value on the boundary nodes and it exponentially decays as the nodes are located inside the region. This approach assumes that the width of the damaged zone along the boundaries is small when compared to the stator dimensions.
The magnetic flux density distribution may be visualized through an isovalue plot in the stator, as shown in the Figure 4 below. In this figure we can clearly see the impact of the punching process and of the mechanical stress on the stator teeth boundaries. The intensity of the magnetic flux density in a narrow region along the perimeter of a tooth is visibly lower when compared to its innermost parts.
The weakening of the magnetic flux density along the boundaries is a consequence of the localized degradation of the magnetic permeability resulting from punching during the fabrication of the stator, as shown in Figure 1.
