Line: about
Lines
Lines (straight segments) can be created:
  • manually (entering extremity points)
  • by propagation from existing lines with the aid of transformation
  • by extrusion from existing points with the aid of transformation
  • within the propagation or extrusion from other entities
Line defined by propagation
A line can be created by propagation from an existing line with the aid of a transformation.
Line defined by extrusion
A line can be created by extrusion from an existing point with the aid of a transformation. This transformation creates the ending point from the source point.
Whatever transformation is applying the created line is a straight segment connecting the source point to the ending point. We talk about a straight forced extrusion.
