Using the Application Macro
Run the Create Edge Port
application macro to create an edge port on a finite substrate. It
creates a bow-tie
structure given the specified parameters and adds an edge
port.
- Open a CADFEKO model containing a finite substrate.
application macro from the application macro library in
CADFEKO.
Figure 1. The Create Edge Port dialog.
- In the Select configuration drop-down list, select a configuration. The frequency of the configuration is used to determine the edge length of the edge port.
In the Select part for union
drop-down list, select the part that will be unioned with the
bow-tie
structure. -
In the Specify points group, specify the named points to
define the location of the edge port.
Points A and B is used to determine the maximum width of the
bow-tie
structure.Point C determines the
height
of thebow-tie
structure. -
In the Specify edge port width group, select one of the
following options:
- using lambda
- The edge port width is determined using lambda. By default, a value of is used, but the value can be modified.
- using width AB
- The edge port width is determined using the physical width AB. By default, a value of (width AB)/7 is used, but the value can be modified.
- using lambda
- Select the Add voltage source check box to add a voltage source after the port is created.
- Click Create to run the script and to create the edge port.
