Effect of Incident Plane Wave on an Obstacle Using Time Analysis
Observe the effect of an obstacle on a plane wave. Obtain frequency domain results using a wideband simulation using the method of moments (MoM). Perform post-processing of the frequency domain data to obtain a time response.
Note: A .pfs session file is included with the example. The time
signals have been set up and you can view the near field results in the time
domain.
Tip: Find the completed model in the application macro library1.
1 The
application macro library is located on the Home tab, in
the Scripting group. Click the Application
Macro icon and from the drop-down list,
select Example Guide.
