Try/Catch
The try /catch block allows you to stop errors from being returned, and allows another block of code to execute instead of the error.
try
tryBlock
catch exception
catchBlock
end
The try/catch statement tries to run the code in the
tryBlock, but if an error occurs, it runs the code in the
catchBlock. The exception is not required but allows you to distinguish
the error type (this is not currently
supported.)
try
a*2
catch
disp('error occurred')
end
