Plotting and Visualization
Create 2D and 3D plots and control their style and appearance.
Functionality
Call the correspondent plot command with the appropriate plotting data as input along with the attributes for controlling the plot appearance and style.
Plot Types and Required Commands
2D and 3D Lines
  • plot produces 2D lines.
  • plot3 produces 3D lines.
2D and 3D Scatter
  • scatter to produces a 2D scatter.
  • scatter3 produces a 3D scatter.
2D Contour
contour produces a 2D contour.
3D Contour
countour3 produces a 3D contour.
3D Surface
surf produces a 3D surface.
3D Waterfall
waterfall produces a 3D waterfall.
2D Log Base 10
log produces a 2D plot with log base 10 in both axes.
Polar
polar produces a polar plot.
One or more plots are contained in the Figure window. When you create a plot, a figure window is created as well. You can also create a figure window manually with the figure(n) command:.
The figure(n) command activates the n-th window; the command close(n) closes that same figure. The command close all closes all windows.
Style and Appearance
Color
  • The default colors for the first three lines in a plot are blue, green and red, respectively.
  • To control the line and marker color, enter the appropriate character code in a format string after the X, Y and Z input vectors.
    Color Code
    Blue b
    Green g
    Red r
    Cyan c
    Magenta m
    Yellow y
    Black k
    White w
Markers
Markers are at the exact locations of the values in the X, Y and Z input vectors. By default, the markers are not shown. To add a marker, enter the appropriate character from the following table to a plot format string.
Coordinate Type Code
Point .
Circle o
x-mark x
Plus +
Star *
Square s
Diamond d
Triangle (down)
Triangle (up) ^
Line Style
The lines within plots are solid by default. To change the line style, add a character from the following table to the data pairs format string.
Line Type Code
Solid -
Dotted :
Dash-dot -.
Dashed --
Dash-dot-dot -:
(none) No line is produced.
Other Functions
  • title
  • xlabel
  • ylabel
  • zlabel
  • legend
  • line
  • text
  • cla
  • clf
  • hold
  • grid
  • axes
  • axis
  • box
  • fill
  • hist
  • mesh
  • xlim
  • ylim
  • zlim
Plot Window Management
Define the preference for the windows to be docked or floating: File > Preferences > OML > Plot.
To change the current docking state, select the window docking icon on the top border of the figure.
The subplot(R, C, N) command creates multiple plots within a single figure window, where:
  • R is number of rows of subplots in the window.
  • C is number of columns of subplots in the window.
  • N is the active plot number.
  • and where the plots are numbered from left to right in a row.
Handles
Plots are considered to be objects in Compose. Each plot object is assigned a numerical value known as a handle. Similarly to object-orientated programming, each object has children that can be modified through the object's handle.
You can modify plots and plot objects programmatically or post plot creation by navigating through the object hierarchy as follows:
