Identifiers
Identifiers are user-defined names that can refer to literals, other identifiers, or functions.
Identifiers must start with a letter (a through z inclusive, upper or lower case). After the first character, letters, numbers, and _’s may be used.
Examples of valid identifiers:
- a
- A7
- my_variable
Examples of invalid identifiers:
- 8abcd (must begin with a letter)
- my_invalid-function (must use only letters and _'s)
The following keywords are reserved by the language and cannot be used as identifiers:
- function
- return
- end (this is a special case and can be used as a function in certain circumstances)
- for
- while
- break
- if
- elseif
- else
- global
- otherwise
- persistent
- switch
- case
- try
- catch
- classdef
- continue
Not all of these keywords are supported in OML, but they are reserved for future use.
